Search the Community
Showing results for tags 'no pulse'.
  • Search By Tags
    • no pulse ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. This is really baffling me. Could use help. Pulled main relay and it bench tests fine. Had a crank sensor code, replaced with new. Timing covers off and all looks intact. Can see OBDII readout at port, but when I test probe connectors at ECU per FSM, I am not seeing power consistently at PIN 1...
