Search the Community
Showing results for tags 'no start 2013 legacy'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hello, I'm new so here it is. I have a 2013 Subaru Legacy 2.5 limited. 237,000 miles. Problem started when I filled up. Car ran rough and I barley got home aprrox. 2 miles. Bad gas, water in it and I wasn't the only one. So drained like 90 % of gas, put in fresh and a bottle of HEET. Car starts sometimes but the shuts off right away. It will start with starter fluid and sounds great. Fuel at fuel rail, pumps primes, good pressure in lines but I can't check actual pressure no shrader valve. No check engine light and no error codes on dash? Even though this is the second new pump I put in, car still won't run. Checked purge valve it is closed. Cleaned MAF Cleaned throttle body, didn't remove it. Can the Crank Sensor be the cause? Maybe a vacuum line is off ? Need some help....I tried an older scanner but I didn't get anywhere with that, it was like from the 90's
