Search the Community
Showing results for tags 'oil leak 2010 diesel tdi'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hi, My wife has a 2010 2.0L diesel TDI (Legacy V) with 189,000km which has always been dealer-serviced. Last service 187,000km in May. I took it to inspections for her last week and an oil leak was found under the engine, which is coating the steering motor/gear and tie rods. The cylinder heads are clean, as is the area around the bellhousing and transmission. The leak seems to start at the oil pan gasket . In May, the dealer made no mention of an engine oil leak, so I suppose that the leak started since they did the work. The engine oil level on the dipstick is 2cm above the "max" reading !! Could this be enough to cause the leak? And would the leak stop again if I drained the oil and replaced the correct amount? Would I need to re-set the computer (for the diesel particle filter) if I did this? There are no indications of a blown head gasket that would leak coolant into the oil. The oil is not brown/green but the normal black color. No coolant is missing. Would a warning light indicate a head gasket issue? I assume, now, that it's simply overfilled. Does anyone else have a hypothesis I should test (and how to test it)? Thanks Jeremy (in Switzerland)
