Search the Community
Showing results for tags 'oil pan gasket'.
How to verify mechanic (corporate shop) destroyed my engine
Todd Toddman posted a topic in Shop Talk
Driving my Outback home from Midas on Tuesday (1/18/22) the car died coming over a hill and wouldn’t start back up. Towed it back to Midas where they checked the timing belt and drained the oil which had metal shavings. Midas doesn’t want to open it up to investigate. They say they are capable and equipped, but they no longer do that kind of work. I realize that there’s a 95% chance the engine is toast. Before I replace the engine I need to open it up and find out what happened. Could they have done something when replacing the oil pan gasket that could have caused it to seize up? on December 23rd they had changed the timing belt (and cam shaft seal), but left the bolt on the tensioner loose enough that it slipped. I had shown up to pick it up, started it, noticed it sounded weird and turned it off after a minute. The mechanic came out and had me start it again. It ran for another minute while we listened and tried to figure out what it was. They looked it over the next day and they said it was fine. I have driven the car probably 400 miles over the last 4 weeks. Is there still a chance that the engine was damaged by the timing slip, but wouldn’t completely fail for a month? What would it look like? Or, was it a mistake having to do with the oil pan gasket? What should I be looking for?- 26 replies
- oil pan gasket
- oil pan
- (and 4 more)
96 legacy wagon, 2.2, Automatic. Ok so im in middle of head gasket replacement. Engine is out and on stand, heads have been removed and sent to machine shop, 1. Oil pan gasket. I got a felpro gasket from RA. Everyone says to use the RTV. I have grey RTV, non anaerobic. Should I use the RTV really? no biggie,, just feel dumb for buying the cork gasket from felpro. a. There is a return or pick up tube inside the oil pan someone told me to replace the grommet/o ring inside but haven't seen it for sale ,, is this a Subaru only part? 2. Block Preparation I shop vac'd the engine off and used a razor blade to scrape remnants of the old gasket off, I also took a scotch pad with some carb cleaner tryin to get them real clean, but they seem stained. I also used some gasoline wiping down the face of it. a. The block has 2 circular guid/plugs on each side to help the head stay on or something. Two of the head bolts go though these things. One came out and stuck on the head.. I pulled it off with some pliers. I didn't crush it or oblong it. Not sure about if I should reuse this,,? Do I need them? what if it don't want to go back into the block. b. am I hurting my motor by having the engine on the engine stand and turning it so my oil pan is sticking out side ways instead of down? c. The block surface is for the most part clean,, no debris,, seems smooth. Anything else I should do? I also have wiped out the cylinders (the pistons are pretty black on top.) Thanks.
- 32 replies
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
Anyone ever use permatex ultra copper to coat a oil pan cork gasket . Thinking this because of its extra adhesive qualities ?
