Search the Community
Showing results for tags 'oil pump'.
Hi folks, So I'm planning a road trip in my BRAT in a few weeks, and decided to do a little preventative maintenance. Had a messy oil leak and a some ticking, so I decided to replace seals and the paper gasket on the oil pump. I think we all know what happens when you remove an oil pump on...
- 17 replies
I have an 86 BRAT that needs a new oil pump, now I have learned that these pumps are ridiculously hard to get these days. For now I am getting an original replacement pump, however odds are I will have to replace it again at some point in time. Lots of you will probably say to just engine swap an EJ...
My oil pump shattered and it's stuck in the engine. Here's the back story: I was replacing the oil pump in my 85 Brat when, while removing the old one from the engine, I turn around for a second and my dumb friend decides to use a mallet to get it out. The oil pumps are know to shatter and naturally...
I had my oil pump fail on my 1987 ea82. The belt pulley broke off the shaft. It seems the rotor seized in the block (see pictures) and I am not sure what could have happened or if metal flakes got in between the rotor and block because it looks like the rotor had been scraping as you can see in pict...
I'm sure this has been asked before. What Sealants are to be used on these applications? Oil Pump: Oil Pan: Rocker Covers (I know there is a seal that is there already, but from what I have seen "on the net" is it still doesn't hurt to run a bead around the Cover Lid Lip) true or fa...
- 9 replies
- Oil Pan Sealant
- Oil Pump Sealant
- (and 7 more)
Hello, I was talking with a reputable engine builder about my engine EJ25. He told to to look at my Oil Pump housing number in the upper left corner. If it is a 7 or 9 he recommends getting a better pump. Either the 11mm or 12mm pumps. Has anyone ever heard of this? I'm going to talk wit...
Hello! I have oil leaking from front of engine and would like to remove my oil pump to check for pump and seal failures. I am wondering if anyone has had experience performing this without removing the engine or if this would even be possible. I would love to hear any advice/steps involved in t...
- 6 replies
- 99 Legacy outback
- Oil pump
(and 2 more)
Tagged with:
I've broken the outer most bolt for an EA82 oil pump. This is the bolt closest to the ear of the mickey mouse seal. Whats the likelihood of an oil leak if I finish the re-seal and t-belts? The other 4 bolts are fine and torqued down. I've tried drilling the bolt out because it broke...
Help request: I'm trying to keep my one and only car, 1984 Subaru GL wagon (manual, dual 4wd, 1.8L) going. Disclaimer: I am not a mechanic, albeit reasonably handy with mechanical things. It has problems going uphill, sometimes even in 1st gear, especially when it's cold and snowy. I suspected the v...
Guys! there's so much info on here about this notorious tod. but i guess i'm curious because the videos i've seen to listen to the sound are all very persistent with a steady tick. i'm reading up on it because... well, i have it. i've had it for a few k's now. it is getting louder. it stops abru...
I recently replaced my timing belt and pulleys, oil pump, water pump, cam seals, main seal and thermostat (thanks for the videos miles fox!) When i first started the car the passenger side timing belt pulled backwards towards the firewall on the cam pulley and is was riding pretty close to the...
- 4 replies
- timing belt
- oil pump
(and 3 more)
Tagged with:
