Search the Community
Showing results for tags 'old gen'.
Hey! I've been eyeing up an older GL, and I honestly know way more about the 1st Gen legacy than I do the GLs or any others. Looks like she's got almost 205K on her, I'm just curious about problems with these. Or perks, I ran away from subaru through peer pressure with my 92. I'm really wanting to get another one! Anyways, let me know.
Tell us what you've been up to, with your old-skool Subies. Here we go: Loyale's: Changed out the A/C and Alternator Belts on the Sedan. Whoever maintained it before had SOA Subaru Belts on there... Part numbers: SOA543100 SOA543102 One, but not the other, are still available from Subaru. A literal chunk was missing from one of the belts, so when turning and putting load on the P/S Pump, it would catch that spot of the belt and then slide producing an interesting squealing sound. Picked up Gates PoweRated (green) belts. Part numbers: 6839 (.5" x 39") 6845 (.5" x 45") Working well, however noticed a lot of green dust around the area of the belts now... probably need to retention the belts now that they have less memory of being in the package. Since I had some EA82 Wagon factory rear coilovers, I wanted to see how much of a lift would be gained over the factory Sedan rear coilovers. Laying on the ground next to each other is a visible difference, the Wagon Coilover setup being Longer over all. (Wagon Set is from older GL model that still had adjustable height. Currently on the lowest setting from factory.) On the car is a noticeable difference as well. The rear was "jacked up" like a hot-rod... drove it like this for a while but then decided to put the sedan coilovers back on to keep the rake even and stress out the rear CV's less. Stock Sedan Coilovers: Wagon Coilovers Both photos were taken after driving and settling in the suspension. Swapped out the brake pads and shoes on all corners. The rear shoes were still the factory ones with the Fuji logo and painted in the same color as the body. (Onyx Metalic) This is somewhat common on these older Subie's with under 200k or so. Depends on how the car was treated. My dad rebuilt the P/S pump on his Loyale wagon, as it was puking all over. Kit part number from Subaru: 31263GA470 $37.28 before tax. Had everything except for one of the o-rings on one of the inlets or outlets, but was able to make do. Replaced a couple Water Pumps on the Loyale's as they were getting noisy and weepy. Can still get these through Napa and the similar parts stores. Funny the box the pump comes in from Napa has a GR third-gen Impreza on it for decoration. 2nd Gen's: The tailpipe on the hatch finally needed attention. Right where the muffler pipe was welded to the axle-back section, it had just rusted away to where there were threads of metal just on one side holding the (now almost two) sections apart. This allowed the muffler to swing around under cornering and bumps. Wiggled it off the rest of the way by hand and then did the right thing and just added a length of straight-pipe... exhaust is carried out past the body and now there's more Subie rumble. Cost? $Priceless. Also on the hatch: Was driving, then stopped at my destination, and then noticed steam venting from under the hood. "Great..." Popped the hood, sure enough, it was the soft coolant bypass hose that goes from the intake manifold to the top of the block. A tear had opened up just above where it was clamped to the nip on the block, sending a stream of coolant forward onto the radiator, hood, and in a puddle around it's area of the block. (Did a nice job cleaning the oil in that spot) More of an annoying leak if anything... so filled the radiator back up with water and then limped it back home several miles on the freeway and backroads, keeping the revs low as possible. That little hose, and it is small, like vacuum line size almost, was $20 some dollars through Napa, plus it would be a week-out shipping from East-Coast! So I said yeah no, I don't need their pricy custom fit line, when I can make my own. Removed the distributor, as it was in the way. Plucked out the old hose, measured it, and then installed a length of hose I had laying around that used to be fuel-line. Put the disty back in and hey, just saved $20 and a week's worth of waiting. So what have you guys done recently to your Subies? Searched until my eyes were sore, but couldn't find the OG thread started way back when...
Hey USMB The Car: 1983 MPFI Turbo Brat - 170,000 miles 2" body lift 5-sp D/R Transmission Swap (originally 3-sp auto) Water Cooled EA82 Turbo Swap (originally oil cooled) EA81T The Problem: I am having issues with the brat running rich, with a lot of fuel in the mixture. I have replaced temperature sensors, air flow sensors, the O2 sensor and i am still running into the same issues. as a result, my fuel mileage is around 19 MPG, and i have a strong hydrogen sulfide smell (almost an ammonia smell) coming from the exhaust, especially when i spool up the turbo and bring the RPM's up into the ~3000 rpm range. My concern: The engine was designed specifically for the Oil-Cooled turbo in 1983 (in '84, they were recalled and replaced with water cooled versions), I have a suspicion, because i am running out of options, that the computer for the MPFI was not designed for this specific turbo. As a result, it has mismanaging its fuel-to-air ratio; causing it to dump more fuel in than is necessary because of the extra amount of air volume it is sensing, then calculating. Does this prognosis seem in any way logical to more knowledgable USMB members?
Got a 82 GL 4x4 wagon about a month ago. Im really stoked on it its a good runner for the most part. the CV axel went out on it and i had it replaced. Im looking for a new radiator because mine is cracked so i have to keep topping it off. im also looking for some external body parts; rear bumper, front mud flap. maybe a whole new front grill assembly. If anybody is around snohomish county area and has alot of experience with the old gens i would like to meet up and have someone take a look at this wagon and point me in the right direction of what i should do next on this thing. and maybe go rally around (; cheers and thankyou!
- 1 reply
- Snohomish county
- Old gen
- (and 4 more)
This is my sedan what do ya think? i will more pictures up later today.... This is nikki, shes a little rough around the edges but overall shes not too bad A little surface rust never hurt anyone eat sleep shift Chocolate brown interior <3 More interior Them carpets be lookin great Just broke 210K Shes still gettin warmed up And here she is sitting at the gas station more photos of the engine bay and all that fun stuff will be posted later, i got some questions to go along with them
