Search the Community
Showing results for tags 'power light'.
  • Search By Tags
    • power light ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 3 results
  1. Some help needed again... 1989 XT6, FWD, 4EAT automatic transmission. When I start the engine, the Power indicator light on the dash blinks 16 times and the idle speed is very low. I'll read deep into the FSMs and see about retrieving any codes, but I don't see any at the ECM in the trunk...
  2. When driving my Subaru outback 2002 the green power light will start flashing uncontrollably and does not stop. It comes on occasionally and goes away after turning the car off and on again. I topped up the transmission fluid after realizing that it was low. I have been experiencing loss of power at...
  3. Hello. Thanks in advance for reading. A bit of a long post, I'm trying to provide as many details as possible. History I recently swapped a '95 4EAT (90k) and rear differential into my '92 Legacy L AWD Sedan. The original final drive ratio was 3.90, and is now 4.11. However, the winter tires I am...
