Search the Community
Showing results for tags 'power loss'.
Hi Guys, having a problem with my 1999 legacy (30th anniversay edition) 2.5l auto. I've had a search through the forums but not seen anything that matches, hopefully someone has had a similar issue! Since I bought it 2 years ago, there's been an intermittent issue with power in the low gears where occasionally i'll go to put my foot down from stopped or from low speed and nothing happens! The car rolls forward but only at <5mph. Theres engine pitch drops which I can only compare to when I accidentally try to pull away on my old bike with the choke still on. 2-3 seconds later the power kicks in and all is well! This happens 1 or 2 days a week and the rest of the time its fine. More recently (3 weeks) I've been getting a short judder when idling, which is worse on a cold startup. This is followed by what feels like slipping when pulling away. Generally fine once into 2nd and above. I've did think it might be the transmission starting to go, but no problems in the higher gears, no slipping going up steep hills/under load (other than when pulling away on a cold start) and gear changes are mostly smooth. ATF is at the correct level and still looks to be in good condition too. Spark plugs are about 10,000m old, air filter was changed 6 months ago. Next step was going to be changing the fuel filter, but by the looks of things I only have an in-tank filter, not one under the hood so I was wondering if anyone here has any ideas of what to try first before I go fiddling around in there! TIA
The title is a little misleading, but I don't know a good way to describe it. I'll start with some background. 148k miles, just had a timing kit done on the car. Replaced the engine coolant temperature sensor after reading that this possibly was the cause for my rough idle and the engine cranking, but not catching when warm starting. By the way, this has totally solved my problem (fingers crossed).. this forum is awesome and thank you to all those that contribute... saved me a bunch of money on that fix.. But now, I'm just noticing (I don't know if it is because before I replaced the ECTS my engine was always running rough, or because I knocked something loose in the process, or what) when I'm accelerating, it doesn't accelerate smoothly. It seems to get through the first gear normally, then when accelerating through the next gear I can feel (and see the tachometer) the car kind of oscillate between accelerating at a predictable rate then slowing down (but still accelerating) then back up, and down again, etc. When watching the tachometer it will rise, then stop, then rise, then stop, etc. I don't know if this is making any sense, but I don't know how else to describe it. Any thoughts on what this could be, what to check, fix, replace, etc.? Also, when flushing my coolant and replacing the hoses, I noticed a small leak right next to (below) the air vent plug on the radiator. It is right where the upper hose connects to the radiator where that horizontal plane meets the vertical plane. Again I'm sorry if I'm not describing things in conventional ways... I'm not really mechanical at all, I'm just trying to be these days to save money. Anyway, do I need to replace the whole radiator because of this, or is it safe to use come kind of leak stop... if so, what recommendations for leak stop. I needed, I could provide pictures when I get home. Thanks for any and all help. I did do some searching for these things, but didn't find what I needed. I'm sorry if this stuff has been discussed already, just let me know and I can do more searching.
- 6 replies
- legacy
- power loss
(and 2 more)
Tagged with:
Sorry forum posting virgin here ... but I had an issue last night that I think maybe you guys on here have some smart advice for me Some background: I have had my Subaru Legacy 1996 since 2004 and it has about 140k miles on it now. It hasn't had any major issues lately and has always been a reliable machine. The Event: So last night around midnight after spending some time with the guys, I was driving home on the freeway/highway/motorway at a leisurely pace (around 55-60 mph) and suddenly my car started to lose power. I had to down shift to get any juice from the car and made it to exit. When I got to the exit ramp, all the lights on the dash lit up (check engine, oil, etc) and my steering got very stiff, but since I was going only 10-20 mph, I was able to control it and continue rolling down the hill to the end of the exit. I down shift all the way to 1st by the time I got to bottom of the exit, but then I noticed I was getting power back. I slowly made a right turn and drove into an empty parking lot and drove around without any noticeable issues. Luckily I was about 2 miles from home and took surface streets home without any issues. I was in 4th gear heading home and rolled down the window, but didn't hear anything out of the normal. When I got home it was too dark to look under the hood, but this morning I popped the hood. The ground under the car was dry, but the bottom of the car looked oily (but I don't know if that has been that way for a while or if it was new). The coolant tank was empty and I think the rest of the oil levels look ok .. the motor oil was a low but not empty. Anyways, the mechanic I would have taken my car to is closed today so I probably won't be able to get it to him till Monday, but maybe someone on here has some ideas of what this may be all about. Thanks in advance and I am finally no longer a posting virgin!!!
- 11 replies
- power loss
- check engine
(and 2 more)
Tagged with:
