Search the Community
Showing results for tags 'power steering'.
  • Search By Tags
    • power steering ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 15 results
  1. Hello everyone. Just got done moving my High Compression EJ251/EJ25D hybrid from a '96 Legacy Wagon into a '98 Outback. Along with it I put in a JDM import 5mt from an '05 Legacy GT Turbo wagon. 4.11 end range. This motor and this transmission makes a perfect ride. All except for the f...
  2. Has anyone ever found a manual steering rack that will fit a 1999 Legacy? Been looking around and just not sure if any old Subaru manual racks would fit. I've read rumors of people using Ford Pinto manual racks.
  3. Hello, Over the winter I got my hands on a power steering pump o-ring, the hose that goes from the reservoir and pump, and the two clamps for the hose. This is to hopefully fix the whine. From what I've read on here it seems pretty straight forward: take the one bolt off, quickly lift hose, pop ou...
  4. 2010 Forester with 90000 miles. About 3000 miles ago I changed the power steering fluid with the Dexron III. Everything was fine but recently it developed a problem: when the motor is cold the power steering starts binding. To avoid binding I put the transmission in neutral, raise the...
  5. Does anyone know the overall width of an EA82 power steering rack WITHOUT tie rod ends installed?
  6. The pulley that adjusts the power steering belt (unsure of what it is called) has seized. Is there a way to loosen it up by cleaning and lubricating it? Or do i need to replace the pulley altogether? I have an 87 3door with a FI 1.8. If i need to replace it, I sure could use some advice on where to...
  7. I'm having a problem with a power steering squeal on my 2011 Subaru Impreza. It started when the temps starting dropping. I've replaced the O-ring and the hose clamp to it. I have also removed as much of the fluid as I could and replaced with new. I'm having no air/bubbles in the reservoir when th...
  8. Is the power steering pumps the same on the GL's and XT's? On Rock Auto, they list a kit for the XT, but not the GL. I'm rebuilding mine and things would be easier if I could just get that kit and be done with it.
  9. I'd like to have an integrated res on top of my '01 P/S pump. I can't seem to get a good answer from parts stores online... Is this even an option for a 2001 or am I stuck with a remote res? Jason
  10. Does anyone know where I could get the pressure hose for the power steering for my 1998 Impreza?
  11. So about a month ago I noticed my power steering started to get harder and harder to turn. About a week and a half ago it began to make noise. Last week I replaced the pump and yet still no change. Today I blew an axle...yay me....so as I was under the car checking out my busted hub and axle, I noti...
  12. so i was on a road trip and while on the highway my battery light came on and i noticed a difference in my power steering. i pulled over to check it out and both belts for the alternator and powersteering had fallen off the "pully" that links the 2. i noticed that it was just loose so i got the belt...
  13. 92 Loyale with 173000 miles. This past weekend I finally attempted to reseal badly leaking power steering pump. I did not know how to treat a copper gasket inside, so I applied an anaerobic sealant to it, and assembled everything back. The pump is still leaking and I cannot find the source...
  14. Hi all! Its been a few years since I have posted here but hello to all! I am involved on a team at my university that is building a contraption of sorts. I was wondering if I could be pointed in the right direction about the following information: What is the OEM subaru # for the power steeri...
  15. Hey all, first time using this forum. I have a 2005 Legacy L, 150K with various problems, but runs great. There is a minor oily fluid leak dripping from the jack-up plate behind the oil tank. I took a close look and noticed that the steering boots are broken which is right above the jack-up plate...
