Search the Community
Showing results for tags 'pressure plate'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. I have a 5 speed manual front wheel drive ea81 that I am wanting to fit an ej22 into. Here are the options I am looking at: FWD Impreza transmission: I read that the impreza ej22 fwd transmissions are 23 spline and so are the hubs of the ea81 cars. I also read that to use an ej22 transmission, I could use the front and rear crossmember pieces out of an xt6 and the center one out of a wrx. If so, are they a direct bolt in? And what year wrx would I be looking at? And is all of this possible? Is there any way I could fabricate some sort of crossmember or modify the original one to fit an ej transmission with just a drill and an angle grinder? Reusing my stock transmission: With these parts, would they mate up together? -ea81 clutch -Flywheel redrilled to the ej pattern -xt6 pressure plate. (I don't know if I have to get another throwout bearing or if I can reuse the one that's in there). -Adapter plate since the shaft of the ea transmission is longer than the ej transmission. Ea82 transmission: Readily available and really cheap. From what I understand they are pretty similar to the ea81 transmissions too, and I can pick one up with significantly lower miles than my current one for pretty cheap so I'd be willing to do it if it's not too complicated. The thing is that my stock transmission has 250000 miles on it, so I was planning on replacing it anyways and I'd have to pay $400 for a redrilled flywheel and adapter plate from sjr since I don't have any good machining tools. I was thinking that for that price I could just get a fwd ej transmission, am I right?
  2. Hey all, The title is incorrect. It should read "cannont turn Counterclockwise"... I have been working on my swap (1993 EJ22 into 1992 Loyale), and have run into a disheartening problem. I had a hard time getting the motor to line up while putting it in. So, what I did was loosen the clutch pressure plate (PP) bolts. Motor went in with no problems. This is where my stomach kind of dropped.... I put a socket wrench on the crank bolt in order to turn the flywheel so that I could tighten the PP bolts. Well, I made it about 1/4 revolution (counterclock-wise) before it siezed. Tried a little extra pressure, but I'm pretty sure It'll just undo the crank bolt that I've already torqued... I can turn the crank clockwise with ease. There is one point at which it feels like it drags on something slightly, but it'll still turn (clockwise). The only thing significant that I did to the motor, was recondition the heads, and replace gaskets. Do I need to pull the motor back out? Why can I turn it one way, but not the other?? Thanks, Greg
