Search the Community
Showing results for tags 'rear defogger'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hi all, So like many folks I'm suffering a non-operational rear demister on my '07 Outback wagon, but the symptoms don't fit all the threads I've read on the subject (here and elsewhere). The basics; the dash switch is functional, the light comes on when the button's pressed and goes out after the timer period, the relay clicks, both fuses are sound. Originally I was indeed affected by broken wires in the tailgate boots; replaced sections on the broken three wires (including the hot wire to the demister) and all was well - for a few days! The situation now is that I get 0V measured at the +12 side of the grid, however if I unplug the grid at both sides and measure at the plug I've taken off the hot side, I get 13.5V! Plug it in and it sucks down to 0V again. Now I can't see how the grid could possibly be a dead short, as it were - yes there's an electrical path across it but the whole point is that it's somewhat resistant else it wouldn't heat up right? I mean many folks talk about having broken lines across the glass but no-one talks about having ultra-conductive lines right?! I also noted that (with the engine not running) I seemed to measure 10.5V before the weird condensor unit that's attached inside the tailgate, but 13V or so after it (voodoo, like I say). Can it be that some part of the signal path is adequate to pass a bell-test or measure a good voltage but when it's expected to pass a serious current (to operate the grid on the glass) it 'fades' and can't pass enough current? So any suggestions folks? I'll admit to finding electrics to be voodoo - I'm much happier with digital systems where things are just on or off Thanks, Ian
