Search the Community
Showing results for tags 'rear strut replacement'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. What I supposed to be a relatively easy task has once again morphed into a nightmare. I bought kyb's 334164 (right) and 334165 (left). They did not come with a "bump stopper". It appears these 2 units are identical except for the brake line hose support location. I also supposed that "right" (334164) means passenger side. Someone please tell me if such is not the case. I watched that guy's videos on how to remove, rebuild, and replace the strut. I got the broken rear strut out without a whole lot of heartache. As I now try to stab the rebuilt unit into place, there does not seem to be enough room to maneuver the unit into proper position. The bottom of the strut is hitting the hub and drive axle while the top of the mount is close but not inserted into the 3 holes in the cab. I pried down the wheel hub some but it wasn't enough. I feel as if I need to somehow compress the shock itself in order to shorten the assembly enough to make it easier to get lined up and bolted into position. It can't possibly be as difficult as I have made it to be. Can someone please help?
