Search the Community
Showing results for tags 'ride height'.
The body of my GL wagon is sitting 3/4" low on the front driver's side. The struts are old/original, so I plan on replacing them to (hopefully) level things out. My mechanic wonders if the front driver's spring may have lost its temper and is part of the height problem, is this possible? If so, where do I find a new front spring?
- 5 replies
- strut
- ride height
(and 1 more)
Tagged with:
I am a new owner of a 1992 subaru legacy wagon (140k) with factory pneumatic suspension, recently the "hi height" switch, has been rapidly flashing after roughly 10 minutes of driving. The suspension appears to be operating correctly, isn't bottoming out, isn't sagging, the compressor sounds like it is operating correctly. My question is why is the "hi height" switch flashing and what are some possible solutions before it goes to the dealership. Thanks
- 1 reply
- air suspension
- pneumatic
(and 2 more)
Tagged with:
Is it true that you can use Mazda Miata rear shocks to lower the rear of an ea81? I have a fwd hardtop, so I can't just adjust the trailing arm to lower it.
- 12 replies
- 1
- ride height
- springs
(and 7 more)
Tagged with:
