Search the Community
Showing results for tags 'running rough'.
-this is a 1996.. or 94? ej 2.2 that was swapped into a 89' touring wagon. -has been running fine/great for last 5000 miles or so but yesterday it started running rough and idlle keeps drifting up to 2000rpm, like when i start it cold but tapping the gas doesnt make the idle drop back down. -it is also throwing a code on the ecu that is two slow blinks and four fast blinks. gonna go now and try to find a code guide of some sort .. . . . .it also seems to drift between 700 and 2000rpm on its own... and when it is down around 700rpm it runs really rough like its going to die.
- 1 reply
- funny idle
- running rough
(and 1 more)
Tagged with:
My Loyale, which I finally put on the road less than a month ago, has been going through a million issues, which I fix according to the priority of the problem. But it IS on the road!!! Current problem is reaching urgent. As I try to recall from the '92 I had, it feels similar. I believe I may either have fuel filter blockage, or injectors plugged. It now will hesitate fairly severely going up any type of incline, which I can push it through with more gas, but it kinda feels like a plugged fuel filter. Am doing that today or tomorrow, adding injector cleaner, and will see after that if it is resolved or not...
- 16 replies
- injectors
- fuel filter
(and 3 more)
Tagged with:
