Search the Community
Showing results for tags 'rusted filler neck'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. So I have/had the dreaded rusted out filler neck. I went on ebay and ordered a replacement filler neck with vent. I removed my old filler neck and there was a HUGE pile of rusty junk that fell out, the only discernable thing was a white plastic rectangle. The three small steel lines that went up to the gas cap area where rotted as well. The neck I had is not vented the new one is. So first I thought it was to bypass the whole charcoal canister assembly by the right rear tire.... I disconnected the lines to the canister and solenoid and was going to monkey match the thing, but then had a thought in my mind to stop. Does anyone have a diagram of how this thing is supposed to be hooked up? Should I just plug the vent on the new neck and hook it back up as stock or is there a better way? There are 2 small (1/4"?) fuel hoses to steel coming from the gas tank area as well as a larger (3/8"?) line plus the 2" filler line. the two smaller lines went up behind the filler neck and another line the same size came down, they where all rotted and this is where the plastic rectangle piece fell out of. Also a larger 5/8 line from the tank to the canister with a t fitting to the solenoid. As I said I unhooked the canister and the solenoid like an idiot and am not sure how it goes back together or what the plastic rectangular piece is behind the filler neck. Any one with experience?
