Search the Community
Showing results for tags 'seat belt subaru 1993'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hello everyone, the title says it all: Here are some more details: Subaru: 1993 Legacy sedan L model Problem: Automatic shoulder belt does work, but it is now common for it to stop on the track or not move at all. What I've done to fix it: 1. Checked connection of FRONT LIMIT SWICTH & REAR LIMIT SWITCH: Both Work 2. Checked connection of door harness wiring: Works 3. Manually cranked the gears on the motor (motor was removed before process): Works, but a little tight in some spots 4. Checked the cable to see if it gets stuck: Works/moves nice 5. Checked motor by activating RELAYS all worked (belt moves faster when activating relay) 6. Checked all wiring connected to the motor, rear limit switch, and to door jamb striker: Works 7. Took apart the entire door and checked the latch wiring for the seatbelt: Works 8. Checked the gap between the track: No disturbance 9. Applied silicone grease to track and cable: No difference 10. The motor gets hot, but still works fine (the gears are all clean/not broken) 11. There is an error code #13 and #23 (both front limit switches on both sides but they have electricity) 12. The computer in the truck with the relays looks fine, nothing blown. 13. Passenger side belt works really good. This is what i have done so far. Please do not tell me to forget about fixing it and stick with a manual belt. I like the automatic one. Can anyone help me determine what I need to do to fix my seat belt. I must get this fixed and no one knows what to do. I cannot find any replacement belts online or at any salvage yards. Thanks, Aaron
