Search the Community
Showing results for tags 'shielded wire'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. My Forester has a P0327 code. I checked the voltage on the shielded wire coming from the wiring harness to the sensor and it is 0.01 volts, not 2.5 or 5 volts. We have a recurring problem with pack rats getting into the engine compartment. I kill them within a day of discovery, but they do a lot of damage just overnight. The wire coming out from the ECU/ wire harness to the knock sensor pigtail has several rat bites in it, so I assume the 0.01 volt reading is due to another cut in the wire somewhere upstream of where I found the cuts. The harness is very tight and seems largely inaccessible from the knock sensor back toward the firewall, so was thinking of adding a new wire back to the knock sensor from closer to the ECU. Any thoughts or suggestions about adding a new shielded wire? The car has 176,000 miles and runs great, I've owned the car since it was new. The Subaru dealer suggested not worrying about it, but if I can get the sensor working again and get rid of the check engine light without completely disassembling the engine to get to the whole wiring harness, I'd like to fix it. Thanks.
