Search the Community
Showing results for tags 'short block'.
  • Search By Tags
    • short block ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 5 results
  1. I finally pulled the short block (SOA478H600R1) that I purchased a couple months ago out of the box and put onto a stand. Changed out the 7mm oil pump for a 9mm that I had (I don't think I'll need a 10mm as I'm a conservative driver, and this is just for a DD project). Looking at the pistons, they'r...
  2. Does anyone know if the short block from an 03 Subaru Forester 2.5 SOHC with the dual cylinder exhaust ports uses the same short block as an 04 Subaru Outback 2.5 SOHC with the single cylinder exhaust port? I have the short block that came from the Outback and the cylinder heads that came off the Fo...
  3. I am about to attempt an engine rebuild on my 87 3Door and realized how grossly unprepared I am. It would of course be much cheaper and easier if I could find and already built engine or even a short block to buy, but I am having zero luck with that search. My questions for you guys are......
  4. looking to source a remanufactured ea81, just the short block. Or a good working one that could maybe use a rebuild. Anyone in Seattle area have leads? Also curious if anyone has delt with engineHaus in Gig Harbor?? Thanks for any help!
  5. Just finished up some engine swapping and have an extra EA82 engine and a lot of engine parts. Including: - Short block 100$ OBO (NOT rebuilt. about 150k miles, cylinders are clean almost no ridge, was running, doesn't even need rebuild - just put back together) - Heads 25$ each OBO (needs valve...
