Search the Community
Showing results for tags 'should be fun'.
So after a bit of thinking and a whole bunch of 'why not' coming to mind I've decided to undertake an ej swap on my 84' wagon. Since I now have my 83 sedan to drive around throughout the process times not going to be too much of an issue, and with work taking a 4 week holiday over the new year I decided it would be a perfect time to get it done or even just the bulk of it. My car as it sits now is a carbureted ea82 4wd hi/low wagon. The plan: Replace ea82 with ej20 Recase ea82 hi/low gearbox front with ej hi/low front case (Like el_freddo has) except I plan on just keeping it 2wd/4wd. Use a FI Leone fuel pump and FI hose Radiator, unsure on this one, the one in my car needs replacing due to a slow leak so this bit is up in the air. Strip down the wiring myself (What could go wrong) Hopefully someone i know will help with an exhaust, if not get an exhaust made. Swap rear drums to disks, maybe swap fronts to turbo for the 25 spline? This should keep the cert guy happy. Hopefully get it certified no problem (Plan on contacting the guy on monday to hear his thoughts) The Donor: 1993 Subaru legacy wagon 2.0 4wd http://puu.sh/cfeJo/afe1518548.jpg http://puu.sh/cfeIJ/f475a49924.jpg http://puu.sh/cfeHJ/b5e5b012e8.jpg Quite rough on the outside and its been sitting a couple of years but it starts and runs fine with no known faults. At the moment I'm waiting on somewhere to do all this, I could do it here at home but it wouldn't be nice. Would love to do it at work (everything I could ever need there) but they may not like it even over the holidays. But I will see. Will try and rope in some help from friends I suppose as well. So thats where I'm at, the beginning. Cheers, Tom
- 21 replies
