Search the Community
Showing results for tags 'solid lifter'.
I recently got an EA81 hydro motor thats missing the pushrods. The guy I bought it from had a near complete set of solid lifter pushrods(aluminum) he gave me for free and I'm working out a deal for a partial set of hydro pushrods(steel) right now. Can you mix and match the two in the same motor? If mixing and matching won't work, can I run a complete set of solid lifter pushrods in a hydro motor? I'm not sure which set will be easier to complete.. Josh
i adjusted the valve clearance as set by factory specs before putting in the motor but after putting it in i think its off my dad went to give it a first start up and i heard a clunk inside and the belts slowed suddenly when i adjusted the clearance i was told by a few people to pull back the rocker and stick the filler gauge in and adjust until it moves freely but you can fill it slide inbetween slightly. so was i not supposed to pull back? addvice is apriated and a video of someone adjusting valve clearance on a subaru motor would be awesome.
- 7 replies
- solid lifter
- ea81t
(and 1 more)
Tagged with:
