Search the Community
Showing results for tags 'spfi swap'.
I have an 82 brat I am swapping to Fuel injection using @GeneralDisorder guide. The return line under the intake is 3/16 hose and try as I might I can't figure out how to adapt it to fuel injection hose as FI does not come that small. And the return line from Throttle body is like 5/16. Ideas? Also the throttle cable does not reach the throttle. What have you guys who have done these swaps done in order to fix these issues.
I have an 82 brat I am swapping to Fuel injection using @GeneralDisorder guide. I have everything in place and wired up. My issues are as follows. I am only getting 6 volts at the coil. And I'm not getting any spark. My fuel pump works. But only shoots fuel when it is hard wired. It won't turn on in test mode. Nor when I crank it I don't think. The ecu blinks at me when my key is in on which is a good thing I think And the engine turns over. I have looked and read, then looked and read, then looked and read again through the guide and my harness and I really believe I have everything hooked up correctly. Minus the neutral switch and cel wire. Any any any help would be Uber appreciated!!!
