Search the Community
Showing results for tags 'starter relay'.
  • Search By Tags
    • starter relay ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 3 results
  1. Siiiiiighhhh. Okay, so now I'm having another problem with my Subaru Loyale. When I try to turn the ignition off, the key won't come out. It will turn as far as cutting off, but not to the full off position. I use the method the manual tells me, to reach under the steering wheel and put your finger...
  2. So I got a new battery after I had my old one tested at Auto Zone and they said it was bad. New battery is good and worked fine, but after three days I went to start it and I got nothing that time. It can't be the starter cuz that is new too, I had it put in some months back and didn't even run the...
  3. Hello All, My 98 Forester with an automatic tranmsission has just recently decided to not start. I thought it might be the starter so I pulled it and took it to a shop and had it tested. It came back ok. I put the starter back in and the car started. The car will sometimes start and othertime...
