Search the Community
Showing results for tags 'steering wheel'.
I'm trying to find out what is causing my tires and steering wheel to vibrate every time I turn the steering wheel. I replaced the power steering pump and the racking and pinion look fine (no leaks or other visible issues). I also replaced the fluid and bled the system but that did not help. Any help you can provide me with will be greatly appreciated. Here is the video:
- 1 reply
- shaking
- steering wheel
(and 3 more)
Tagged with:
Siiiiiighhhh. Okay, so now I'm having another problem with my Subaru Loyale. When I try to turn the ignition off, the key won't come out. It will turn as far as cutting off, but not to the full off position. I use the method the manual tells me, to reach under the steering wheel and put your finger in the hole where you toggle the little button inside that releases the key, and it does. But I just wanna know WHY this is happening and what to do about it? And is it dangerous to keep driving?
- 7 replies
- igntion switch
- ignition system
- (and 8 more)
