Howdy gents, this is a classic example of: how to pour money and time into car and find out later that it so rusted its not economical to have it fixed by professional but you cant back off anymore. I had my Loyale pre-inspected to find out if it would pass/fail tests, I thought it might need carb adjustment and maybe new valve cover gasket and thats it. Mechanic poked around with hammer and results were that both rear wheelwells are crumbling. Rear crossmember is a mess and he said thats not allowed to be welded and needs to be replaced. Also strut tower is compromised. Problems are on both sides off course. Planning to replace rocker panels as well. Would be a good idea to drill spot welds in strut tower to remove it and do the welding at bench? I'd imagine it would lead to better results than doing via wheelwell & trunk even thou its seems more troublesome. Any dos or donts in this matter?
http://imgur.com/a/VASst
