Search the Community
Showing results for tags 'subaru legacy issues staring'.
I have a 91 Subaru Legacy and it will not stay started when I start it unless it has been sitting for awhile, for example overnight. But if for instance I drive to the store and then shut off the engine and go inside and then come back out and try to start it again, then it will not stay started when I try to leave unless I give it gas at startup and I also have to keep my foot on the gas for several minutes to keep it from shutting off. I just had the following work done on it among other things: engine control module replaced, o2 sensor replaced, fuel pump replaced, fuel filter replaced and entire fuel system cleaned, air intake system cleaned/repaired. This along with everything else that was done came to over $1,500, and the car was in the shop for well over a month. Needless to say I do not want to take it back to the shop or invest any more money in it at this point. However I am curious to know what else could be causing it to not stay started aside from the things that I have already had looked at/replaced. I realize that it is an older car, but up until a few months ago I wasn't having any issues at all with it. I initially took it to the shop only because sometimes it wouldn't start at all unless I started it with my foot on the gas, but that only happened sometimes (though it did begin to occur more and more frequently and had gotten pretty bad by the time I took it to the shop). Is there something else that I could possibly do myself to fix the issue that I am having without spending an insane amount of money? Also, is it hurting the car to keep driving it even though it is doing what it is doing? I only still drive it like that because I have no other transportation at the moment. I also know it isn't the battery because I just had the battery replaced earlier this year, and all of the lights and other functions (radio, e.t.c.) work just fine. Side note: Not sure if this is an issue either, but if I turn the engine off and just sit with the key turned in the ignition (in the position just before starting the engine), then I hear a humming sound coming from the car which usually only seems to stop if I completely remove the key from the ignition.
- 6 replies
- subaru legacy issues staring
- subaru
- (and 7 more)
