Search the Community
Showing results for tags 'subaru', ' legacy' or ' automatic'.
ok so i purchased a 1995 legacy for 500 bucks from a friend that he was sick of dumping money in he spend an obscene amount of cash anyway the speedometer did not work and the shop kept changing sensors after i spent time on forums and this particular forum i was able to bug out the issue so i thought i would share my process as to help others beginning with a generic scan tool i received code P0500 and after some research it led me to speed sensors and how to test with a multimeter they seemed to work properly then i decided to buy a much better code reader and it gave me one specific word that changed my direction of solving this issue it stated fault on sensor "A" circuit that one word told me it was not a sensor so i decided that it was losing signal to the speedo i connected to the plug in the dash and the one at the sensor and determined that the wires were in fact good then i connected the sensor and connected it to a drill and found that it was sending the signal and it narrowed my search to the actual speedometer i took out apart the speedo and found a burnt board pictures below hope this helps someone else solve there issue. i purchased a used speedo from shopearl for 65 bucks also sorry i work with my hand i am not good at typing so please forgive my punctuation or lack there of
hello! so, to make a long story short: my dad’s 2000 Subaru Legacy has been sitting for eight years. We’re finally getting it repaired (or hoping to), or at least checked out, but the problem is because it’s in parking, we can’t move it, unless it’s with a special tow truck, and that’s just too expensive, and the space for such truck isn’t there. The regular tow truck guy basically said I need to put it in neutral first, but since the battery is dead and buying a new battery and starting it again in its condition isn’t really the best idea, we don’t know what to do. I’ve been told about the shift lock trick, but haven’t been able to find any sort of shift lock like the one in the pic. Any ideas on how to put it in neutral? Is the shift lock somewhere else?The guy said he could start it without a battery with some type of equipment, but I honestly don’t want anyone to mess with it before taking it to the official Subaru dealership. Thanks and forgive my ignorance!
Hello Everyone, im currently in a pickle, and in need of assistance. Long story short i placed a 2002 JDM EZ30D into my 1997 2.2L Impreza coupe. along with the entire 2003 outback L.L. bean Bulk head with front wire harnesses. Body Brighton Coupe Engine Ebay 36k JDM EZ30D Wires from 2003 LL BEAN Edition Drivetrain 2005 4.44 WRX 5 spd Transmission/Dif I have communication with the ECU Fuel pump loud n proud. primes as needed new battery starter alternator fuses relays etc. no joke 1 Check engine light MAF. its not installed so I can reach the wires under it. NOT THEE ISSUE. ignition Switch is from the Impreza and not the outback matching the engine Neutral safety switch bypassed 0 volts 5 volts thing done. Automatic gear selection circuit completed. car should think its in neutral. I want to turn the key and start the car... I know I can bump start it. I don't want to. the nice land lord lady saw me drive it in...has to see me drive it out wink wink. in a pickle Everything is working as intended upon the moment of turning the ignition on 1 turn unlock 2 turns speedometer gauge/ecu /fuel pump etc. turn on. 3rd turn-> to ON, every relay clicks starter weakly clicks then Silence. no rumbling T.T Not siezed has compression. Shut up =) Every Electrical ground has been gone thru OCD cleaned repeatedly checked, yep tight n clean. If I left something out. please notice it and ill explain further. Its done as cleanly as it could be done using all OEM parts. OCD OCD OCD SMS, Save My Subaru I Beg you. any info you can give me will be greatly appreciated.
- 60 replies
- 6 cylinder
- subaru
- (and 8 more)
Hello all, recently my auto transmission took a turn for the worst in my 01 legacy but I had a manual from a 98 2.5rs sitting from a old build and it bolted right. But the speed sensor doesn’t. The 01 has an electronic but the transmission was the ol cable driven. Any ideas how to convert the cable to the mechanical without breaking the bank? I’ve looked at cable converters but they’re all for a mechanical cluster. I have a mechanical gauge but no sensor for manual. Any help would be greatly appreciated. thank you Koda
so what i bought . just normal city outback 3.0 VDC model and what it became to, first 5cm/2' lift spacers and larger tires 225/65R17 those had problems to fit there and live so i cut some plastic off there and hamered some stuff with hammer but in end all worked on those tires, and later i went for 7cm/2.8' lift just on spacers nothing else done and it works pretty cool , on high speeds on highway or just cornering tight in city this lift just works. front sway bar still in place , on this gen front sway bar is working with lift , though rear sway bar went off because it cant fit with lift . numbers in cm with 7cm lift front and rear proper recovery points and hili ft jack lift points and roof rack modified from 2001 so now that hi lift jack can be on full use and alike allways nothing is bought everything made by myself and because car was for trips so made something for myself too and to have small fire with us allways . very cmpact but made from pretty strong steel not thin and we sleeping in car too in trips with some foam matress it feels like sleep at home rly for 2 its just great. its taken from previous 2001outback that rusted away so i needed new car.
Hello fellow Subaru enthusiasts! I have been experiencing automatic transmission problems for many years and the time has finally come that I can avoid fixing it any longer. Since I acquired the car in 2011 there has been a intermittent problem with the duty-C selenoid, the transmission has been binding up around corners for a long time, but the car was given to me for free so I never took the time to replace the duty-C. I do not drive the car very far so I have gotten away with this for some time now. When I do drive the car over 15 miles, the transmission heats up and starts to whine under load. After about 30 minutes of driving the scratching/grinding noise between gears is awful, its so loud I feel bad driving it. I have done 3 transmission flushes over the last 6 years, the first flush was because my transmission cooler line broke while driving 60 mph uphill and dumped all my fluid. While refilling the transmission fluid I accidentally over filled it, and drove it like that for at least 2 years. This summer I start a new job that is about 110 miles away and I know my car won't make it, not even once. I need to replace the transmission, one with less miles that does not have quite the abuse on it. I plan to remove a transmission from a matching year legacy when one appears in the junkyard and swap that. Once I find a replacement transmission I plan to bring it to a shop and have them test it before I go through the trouble of swapping it out, but I am wondering if anyone has done a project like this before? If so, were there any unexpected issues that came up? What gaskets should I purchase before so I can change them all before I install it? Is there an item number for a kit with all the gaskets? Even better, does anyone have a link to a similar situation that someone has already posted? Thanks for the help everyone! 1993 Legacy L, 4-EAT 287,452 miles -Mike
Hello, I'm new so here it is. I have a 2013 Subaru Legacy 2.5 limited. 237,000 miles. Problem started when I filled up. Car ran rough and I barley got home aprrox. 2 miles. Bad gas, water in it and I wasn't the only one. So drained like 90 % of gas, put in fresh and a bottle of HEET. Car starts sometimes but the shuts off right away. It will start with starter fluid and sounds great. Fuel at fuel rail, pumps primes, good pressure in lines but I can't check actual pressure no shrader valve. No check engine light and no error codes on dash? Even though this is the second new pump I put in, car still won't run. Checked purge valve it is closed. Cleaned MAF Cleaned throttle body, didn't remove it. Can the Crank Sensor be the cause? Maybe a vacuum line is off ? Need some help....I tried an older scanner but I didn't get anywhere with that, it was like from the 90's
Hello, car was running fine yesterday but today got a crank with no start. Went through the typical. Spark, fuel And fuses And it has all. The intake isn’t sucking a lot of air. It does have some suction but not a crap ton. Any ideas on how to get it running again?
- 1 reply
- subaru legacy
- subaru
(and 1 more)
Tagged with:
- 10 replies
- subaru legacy
- subaru
(and 1 more)
Tagged with:
Any help on finding a 1993 Subaru Legacy sport ecu to engine wiring harness? MT/turbo. I’ve looked all over the place to find one but no luck.
- 12 replies
- ecu
- wiring harness
(and 1 more)
Tagged with:
Hey, all! I've been searching for some info about this 2012 Outback I'm looking at and leads me here. Thought to sign up to read further and probably ask some questions. Seems like a great community here.
Greetings, from the broke highschooler again, and now that I have the information from my other post I have come to the conclusion that I am going to need another vehicle to do what I want to do. Like I addressed in my post, I am not trying to break the bank but still have a vehicle that is reliable for these idaho roads/winters and as a daily driver. If you could give me suggestions and a price to ball park to that would be awesome!
Greetings, I am a broke highschool student who is looking to mod my 1990 Legacy LS sedan, it is not my own right now it's still my parents but i do plan on buying it from them when I start working later this month. I am aware of the options I can have like boosting it or building the whole thing, but I'm not trying to blow it up because I need it for school and for it to be reliable. Any brands for stuff like exhaust's, intakes, cometics, and other smaller stuff. I am willing to listen to most ideas and eventually I will take pic of it and upload them but I have to make the effort. But anyways, any brands to look forward too for mods and certain mods are accept.
- 12 replies
I recently purchased a 2018 Subaru legacy 2.5i limited and I absolutely love it. the more I drive it the more I wish I could hear the exhaust of the car. I have been looking at ordering a new exhaust for it. my question is: Is there any performance enhancements that I could do by swapping out some of the factory exhaust system for a bigger or better system? im not looking to take it on the track or anything just looking to make it sound meaner and if I can get some extra performance out of it id spend the extra money. thanks, Wisconsin Kyle
I have recently purchased a 1996 Subaru Outback with a 2.2 liter EJ 22 engine that I know very little about. so far I have replaced the clutch and the axles and just in time to blow a head gasket . So in lue of just getting another car i have decided to turn this car into an ultimate adventure wagon, ntm b4 I blew the head gasket it had quite a few problems with lack of power and failing gages . at this point i am ready to put a new engine in the gal and do a complete overhaul . being that i am not a mechanic and i have a limitted budget, I have a lot of questions. first of these is; what can i do to achieve 250 hpaw with a 2.2 l engine ?
- 26 replies
WHATS UP GUYS!! Check out my YouTube channel for the most up to date progress! https://www.youtube.com/playlist?list=PLhvLjCFIoC6LFmt17Fu4Pj5WL74FBU0qw Been browsing this forum for a few months trying to get ideas for my project and I finally decided to join and build it along with you guys! Open to any advice/criticism but doesnt necessarily mean I will listen to it! The beginning of this thread will basically be a copy and paste from an existing thread I have on another forum! I'm planning to do wrx engine, trans, suspension components, even dashboard! currently(10/30) I nearly have the front end completed (for now) as it sits now, I am currently on this setup stock brat crossmember modded to accept EJ engine mount and wrx control arms stock brat manual steering rack 1" crossmember spacer wrx control arms wrx knuckles wrx/sti struts 04 sti stock springs stock brat 2 bolt top hat (temporary) brat radius arm mount bracket modded to fit wrx control arm custom tranny mount pic of it arriving at the shop.. yay for selectable awd ouchhh.. nice and crusty time to get a good look at her found this girl as my drivetrain donor (parting out other parts) time to cut her all up
I have a 2011 wrx limited and I'm looking to second hand purchase BC Racing coilovers that were from a 2005 wrx wagon. Would they be compatible with my car?
- 1 reply
- suspension
- subaru
- (and 4 more)
My 14' okie gator airboat. Powered by an ej20 turbo, has a 2:1 belt drive with a 10 blade warp drive prop. It does great out here on the st johns river, just got done test driving it for about 3 days in a row. I have a few questions for you guys but ill wait till tmrw. Till then, heres the boat ! Ill take some vids tmrw too.
Hi I’m new to the forum, I lifted my 98 Impreza L wagon on 05 forester struts and am looking to get bigger AT tires, I understand with 215/55-65/15’s I will need some fender mods, but I currently have 185s on 15 inch steelies and it doesn’t look like I have much room between the tire and front shock, so before I order anything too big I wanted to see if anyone has come across this problem any info and close up wheel well pictures would be greatly appreciated, thank you.
- 1 reply
- subaru lift
- lifted impreza
- (and 6 more)
Hello there fans of the great Subaru ,I have a justy j10, I bought a year I go It wasn't in good condition but I like it ever since I been fixing it up .so far it started from a little fix to a how to become a mechanic . To the point the idle run pure not all cold, runs ok with choke full open and then to high rev,s .I took if off once cleaned up but not much improved, so I AM thinking it's time to go with an other carb in fact a 38/19830,202 38 dgas Weber like carb my question is will it run ? Will be ok? And not use fuel like crazy?
- 1 reply
- subaru
- carburetor
(and 1 more)
Tagged with:
Basically.... About 3 weeks ago car was intermittent no start. Cranking was rough/rumbly and gas pedal hadda be teased in order for it to sometimes start. Attached a missing ground strap and car was reliable for a few weeks. Still had a bit of a rough/rumbly start but at least started and drove. It ran fine, but I pulled the motor for HG job and no spark after re-install. Tested coil pack resistance, tested bad. Swapped coil pack....didn't help. Power to coil pack, no signal to coil pack. Crank sensor & cam sensors pass resistance tests. Checked wiring to ECU, passed. Reinstalled ECU, engine started and ran for 15 seconds including idling and revs but no issue was actually solved... But we reinstalled accessories. Again, no spark, no signal to coil. Fuses tested/examined, so not a fuse. It's a 2001 Subary Legacy Outback 2.5/EJ25. Any advice on what might be going on or how to test the ECU would be great help.
Hello, I am looking at a Subaru where it is a loud ticking noise from the engine. Look at the video linked: It apparently started when the person startet up the car and the car suddenly revs higher and higher by itself. They managed to stop it without any problem. Sounded like a turbo problem, but after a look on it it seems like that is not the case. Don't see why it would tick like that either. Diagnosed the fuel flow into the cylinder and that seems fine... Can the chain make this noise?, even though I don't think that'sit. Its a Subaru Impreza 150hk 2010 model. I am completely new to Subaru. -Thanks for the help
So I got myself a 1994 Subaru Brat (RHD) with an EA81 engine and in the process of swapping in a Legacy Twin Turbo.. :-) Would any of you fine people have a wiring diagram for the Brat (Is it the same as the 1800 gl?) Thanks in advance John
