Search the Community
Showing results for tags 'temp gauge'.
The gauge stays in the middle when the car is on.Even when only the ignition is on, it goes to the middle. Then back down when the car is off.Goes straight to the middle on a cold start, and stays there when warm and never moves (until I turn off the engine).I unplugged the coolant temp sensor (CTS) and turned on the ignition (not the engine) and the gauge went to the middle again. This also kicked on the cooling fans.Then I unplugged the temp sender unit (right next to the CTS) and the gauge still went to the middle again when I turned on the ignition.What is wrong here? Any ideas?
- 6 replies
- engine coolant temperature sensor
- sending unit
- (and 8 more)
2000 Forester Temp gauge hits red during light stop and go traffic or highway driving within 20 minutes, does not hit red just from idling. Temp gauge rises with coolant temp viewed on scan tool. Thermostat opens at correct temp (lower radiator hose gets hot), has new Fail-Safe thermostat. Fans turn on at 95 C. When the gauge hits red the temp is 100 C, highest temp I saw was 101 C, temp stayed between 90 C and 95 C at first but once it hit 100 C it wouldn't drop unless it sat and idled for about 10 minutes. I didn't push it too much because I didn't want to damage anything, A/C off and heater off, ambient temp 80 F. Cooling system was burped when thermostat was replaced and then a week or two later burped again and I got more air out of it. Burping procedure: with spill proof funnel on radiator, run engine until thermostat opens, let engine run and occasionally rev to about 3000 rpm until no more bubbles are seen. I waited about 15 minutes after thermostat opened each time. Head gaskets have been recently replaced. I don't trust the dash gauge, I don't think 101 C should be red-line but it does seem high, I haven't been able to find a maximum temp spec or normal operating range. I haven't worked on Subarus much and this is my first time messing with a Subaru cooling system. I haven't yet blown out the radiator fins, that's on the schedule this weekend. Is this a normal operating temp? At what what temp is engine damage likely to occur? I'm not even sure if I actually have a problem or not with a coolant temp of 101 C.
- 4 replies
- Cooling system
- overheating
(and 2 more)
Tagged with:
Hi everyone, I have a 1996 outback, and it's giving me a weird problem. When my check engine lights turn on, my temp gauge reads fine, on the halfway mark. But when the check engine lights is off, the temp gauge goes up pass the halfway mark. And the check engine lights goes on and off at random start ups. I don't really know what's going on. Before this happened, I worked on the timing belt, replaced the water pump and thermostat. Could it be the thermostat that is causing this weird readings? And what about the check engine light? With the check engine light, I was thinking that it was probably from the engine? When replacing the timing belt, on the first try, it didn't turn on, but I kept cranking it and cranking it. Then on the second try, I think I might have forced the alignment, at one point, and turned the shaft when it was really stiff. ... and possibly damaged something inside the engine. Would that throw a check engine light? And one other issue I would like to address, since I am here. Earlier today, I replaced the resonator pipe and the muffler. bought the package from ebay. they totally shipped wrong parts to me. what a disappointment. The whole package is suppose to be black, but instead, they sent the silver muffler. And when I put them together, the two wouldn't not align. They are twisted at least 1 and 1/2 inches from each other. And they said it fits many 1996-1997 subarus: outback, impreza, legacy. ... And then I noticed, there are condensation dripping out of the connection between the resonator pipe and the Catalytic pipe. Is it just because it wasn't tight enough? But I have screwed completely as far as I can screw (up to the smooth part of the bolt, where the spring would be). As of right now, my outback is in the garage with no muffler. .... :'( Sorry, this is alot, but any help would be appreciated. Thanks in advance. Thank you.
- 14 replies
- Thermostat
- muffler
(and 3 more)
Tagged with:
