Search the Community
Showing results for tags 'temp guage'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. Hey there guys. Mike W here. Damn, I haven't been on USMB in a loooong time! So I recently brought the red Hatchback outa storage. I'm working out a few bugs and thinking I might finally sell this beastie if I get everything proper. But this minor electrical voodoo issue is having is driving me nuts and have the feeling I'm missing something very obvious! I sure hate to post on here but I'm a bit frustrated and could use help! '88 Hatchback (EA81) All the dash gauges used to work. But recently the Oil Pressure, Batt Voltage, and Temp gauges...all quit working. But not all at once! First the oil pressure quit working, then a few days later the temp guage quit, then the volt gauge just quit. WTF?!! The fuel gauge and the rest of the dash works just fine. I can't find any blown fuses. I've checked (and sprayed) all connections in the engine bay. All seem fine. I checked and sprayed connections behind the dash , they seem fine too. Is there some secret fuse I don't know about? Bad ground??? Where to look? Failing voltage regulator? Headlights etc brighten and dim a bit with RPMs and I'm seeing some voltage spikes in the 14.7 range. What am I missing here??? Any help would be appreciated!
  2. My Dash Thermostat is reporting as high as the needle can possibly go, it gets there before the computer reads running temp (190-200). My ODBII is reporting running temp after a proper warm up time. The sensor is a 3 wire, combined sensor/switch. Why would one read impossibly high, and the other work in parameter. I've replaced the sender. All this is after a rebuild so ground? or other ideas please....
