Search the Community
Showing results for tags 'temp sender'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. For the EA81 engine, and 1983 Brat, does anyone know where the Engine Coolant Temperature (ECT) sensor is? There is a sensor near the thermostat housing (which is by where the upper radiator hose connects to the intake manifold I think, passenger side of engine bay) but this sensor is two-pronged which means that, according to all parts catalogs that I've looked at, it is the radiator fan switch, not the temp. sensor that connects with the dashboard temp. gauge. The temperature sensor is just one pronged (at least the aftermarkets that you can buy are one pronged).
  2. Hi all, I've been searching this morning on information regarding the charcoal canister. Anything that I've come across dealing with this, only pertains to 2.2-2.5 swaps.. The Legacy donor vehicle had hit a deer, so the passenger fender/radiator/light/charcoal canister were destroyed. I have the EJ in the Loyale now, and I'm wondering how to correctly hook up the Loyale's canister to the EJ motor. Is this possible? I believe I connected the two (available) EJ lines correctly. But there is the third line off of the cannister that I'm not sure where to hook up. It says VC I believe. My next question is about hooking up an EA temp sender unit, and a fan relay together... I will be hooking up two 10" fans to my brand new EA82 single row radiator. It is identical to the old one that I pulled out. There is a port on the side, that I believe I can put in some type of temperature sensor in... On to the subject... I will be using the EA temp sender so that I can keep the gauge working. I also will be using a 30amp relay/circuit/switch system to operate my fans. I do not want to make a sleeve for the sender, then to put it in-line with the upper radiator hose. My idea is to make a T-adapter that can be used in that radiator port. Any reservations? I was thinking of getting a small length (maybe 1/2" long) of threaded pipe (to the size of the hole..) then attaching that to a T of some sort that I can put in the temp sender for the gauge, and one for the fan sensor... That might not make any sense, my brain is firing sparatically from all the coffee... This is similar to what I'll be using for the fan relay... Any thoughts would be great! Thanks, Greg
