Search the Community
Showing results for tags 'temp sensor'.
Still tinkering away on this 85 DL with an EA82 and a Hitachi carb. To date, I've replaced half shafts, strut mounts, struts, sway bar bushings, plugs, wires, rotor, cap, fuel pump and filter, along with a new compressor and accumulator for the a/c. I ran the car that way a week or so (77k miles on...
88 DL Wagon w/ EA 82. Recently advised to CLEAN MAF, bought MAF Sensor cleaning spray, removed sensor from Body, sprayed it, let dry and replaced. Was VERY careful in Removal, Handling and Replacement, but have suffered Mileage loss shortly thereafter. Tested Sensor in accordance with Chilton Manual...
Have 88 DL Wagon, mileage not as it should be. Wondering if the Temp Sensor in the Radiator for electric fan has any Fuel/Air control thru the ECU, or is it for fan control ONLY???
I have had no problems driving the car. Parked it in the garage last Friday. Monday morning, it won't start but it does turn over and cranks. I have checked the following things: -- spark, good in #1 cyl. Didn't check the rest -- fuel, appears to be getting fuel, didn't measure fuel pressure...
- 13 replies
