Search the Community
Showing results for tags 'third eye'.
Anybody have any experience converting the EA81 Quad Headlight setup over to the EA81 Single Headlights with Cyclops? Or know of a writeup? Believe that I have everything needed: Single Headlight Core Support Single Headlight Buckets/Bulbs Single Headlight Bezels with Turn Signals and Pigtails Third Eye (Cyclops) Full Assembly with Pigtail Third Eye Grill Relays that sit on the passenger side (RH) strut tower Third Eye Switch from factory that's used with the HighBeams on. Part that's confusing me is how the wiring goes from twin lights, one for low and one for high beam, to single units that do both functions. Guessing that the turn signal wiring that goes to the front bumper will have to be rerouted so they will go to the corner flashers of the Single Headlight Style. And then there is adding the Third Eye to the equation... The easiest method in my head; Take the entire front harness from an '82. Place that harness in the body of the '86. (thats the year of the EA81 chassis its going into.) Not sure if the connectors between those years are the same or if they were changed? I have an '82 that is badly rusted and is more like a donor vehicle. Ideally would take the cyclops light setup from it and put it on the '86 which is still structurally sound.
Found this on craigslist yesterday and couldn't resist going and getting it. Even with the supposedly bad motor it was still worth getting it. Once i got back home with a fresh battery and a little cranking she fired right up and ran fine. even has a skid plate seats are reupholstered wood shifter Factory cruise control in orange along with cluster ac
