Search the Community
Showing results for tags 'timing belt'.
  • Search By Tags
    • timing belt ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
  1. Driving my Outback home from Midas on Tuesday (1/18/22) the car died coming over a hill and wouldn’t start back up. Towed it back to Midas where they checked the timing belt and drained the oil which had metal shavings. Midas doesn’t want to open it up to investigate. They say they are capable and...
  2. It’s kind of crazy to think how long I’ve been in the Subaru game and yet I’ve never replaced a 2.5 head gasket! I only want to deal with this repair once, hence this thread: I was under my wife’s 1999 Forester for an oil change over the weekend and noticed the bottom of the driver’s side of t...
  3. I've been replacing the timing belt and pulleys in my 1999 Legacy Lancaster (a Japanese import similar to an Outback) with a kit from Amazon, I noticed that the rusty looking "guide" just left of the top cam on the right side (looking at the engine from mechanic perspective) was actually a small pul...
  4. Got a 2008 Subaru Legacy, I just noticed a large chunk of my timing cover has fallen out. I was looking for a replacement piece, but they all come in 3 parts and for some reaso, my cover is 2 parts with a larger left side. I still have the chunk that fell out would i be able to make a tempor...
  5. The vehicle is 2010 Forester with 106000 miles. The YouTuber brianmobil1 mentioned that the top of the tensioner rod must be smooth. Mine is warn out. It is not leaking oil and I was going to reuse it. Should I replace it? Thanks for looking, Sam
  6. Hey Guys, Have a buddy in Salt Lake who blew timing belt on his '10 Impresa 2.5. Dealer is telling him $3,000 to change belt, repair bent valves etc... Any recommendation to where he could get a second opinion &/or better deal on the repairs in/around SLC? He is a college student & not much $$$...
  7. Hi all, Recently had the timing belt on my DOHC skip some teeth. Was a brand new belt kit including tensioner. Was a Gates-brand. Well, I reset everything and about 500 miles later I believe it has skipped at least a single tooth, so I've parked it. I will purchase a brand new Subaru OEM belt a...
  8. EJ251/25D hybrid Original posting with backstory: timing belt jumped a few teeth headed up I-70 two days ago. Reset timing, and it runs well, but noticeable tick coming from the passenger side of the motor. That is the side that the belt skipped. Yet to do a compression test, but...
  9. Hey all. Just the other day I got my 95 Legacy wagon back from my mechanic I had him do the ultimate timing service. The thing is when i bought the car it had 145K on it now it has 180K, it came with service records and the only thing referring to timing belt was at about 60K it had the water pu...
  10. Hi All, This is my first post here. I recently did a timing belt on my 1999 Legacy Outback Wagon, with a new water pump. Job went well, all parts bolted up and timing came out fine, no problems running now. However, even after burping the cooling system with a radiator bucket, multiple times, t...
  11. So there has been alot of questions about bent valves from timing belt failures. It's been my experience that if the belt breaks, it surely bent valves. But sometimes, if the belt just skips a few teeth, things are okay. Example : this '06 forester started running incredibly rough about...
  12. My EA82 is running better than ever... for now. The driver's side timing belt is slowly getting eaten away. The cause? I'm not sure. But what I do know is that the belt is walking off the back of the camshaft sprocket and the crankshaft timing gear... and the tensioner... and the idler pull...
  13. Hey Everybody. Long time no write! It's been too long since I posted anything.. Busy with work and things. You know the drill. In the next week or so, I'll be performing the EJ20 swap in my 05 Forester. My engine has over 180 miles, has oil leaks, including the rear main seal, and has some really...
  14. I removed the passenger side head for another issue. I turned the crank so the flywheel was on the 3 marks and the passenger cam pulley had the timing mark pointing up at the timing cover mark. My question is what is going on with the driver's side cam pulley. It has 2 marks on it - one pointing...
  15. Hey, Can anybody tell me what type of marker / manufacture that will stay on and show up on a timing belt / and gears? I want to put marks on the gears, and rotation direction on the belt. Thanks
  16. Hello all, Our family workhorse '05 Outback Wagon 5-speed has 85,000 miles. Was at Midas today to get the brakes done. There is a small oil leak from the front crankshaft seal. Should I consider doing the entire timing belt/water pump at the same time? Midas is quoting $825 for the timing belt,...
  17. I changed out original 276K motor with used 76K . Outback is 5 spd manual. Did all wear point replacement and of gaskets / 5 Star HG. Car had been running great. Normal MPG 28 or so. No symptoms displayed before breakdown. Sold to my friend and has now come back to me for the repair. I did not...
  18. Okay, it's a 2006 Legacy 2.5i Limited. I have owned this car for about a month and half or so. It has 99,500 on it. Today I am driving and the engine loses power/stalls, I try to restart it, with no luck. I get the car home and want to make sure the timing belt was moving properly. When I...
  19. I'm in need of help. I have a 1996 Legacy GT with the 2.5l motor. I changed the front camshaft oil seal and the timing belt. During the process things got out of wack. The engine will start and seems to run fine on fast idle (2500-3000 rpm) for 15-20 secs. Idle drops (below 1000 rpm) engine star...
  20. Hey everyone, Recently, I got back from a holiday and had my 89'GL sitting there for a month. It got driven a couple of times, but was dead when I got home. I replaced the spark plugs and she was up and running. Ever since though, it's ran like crap. Shakes with a very low idle, back fires when...
  21. Hi all/anyone Im brand new to subaru, i have a very well looked after 55 plate forester. had the timing belt done today and a blowing exhaust patched. the car now sounds like a tornado jet with a harley up its back end. its faster. and more responsive but the idle is shocking. the car visibly s...
  22. Hi Gang, I'm a first-time Subaru owner 'hopeful' and I am eager to know your opinion about purchasing a 2001 Forester, that has had some repairs and a lot of preventative maintenance. Thank you in advance! This is for sale by a self-proclaimed Subaru mechanic (not Subaru certified). He supp...
  23. Hello All, Been reading this forum for some time which has been an incredible help with my amateur knowledge of Subarus. I have a 1999 Forester that's really getting up there in miles, currently at 277K. Had the timing belt changed at 258K back in October 2010. As you can tell I haven't...
  24. I have just recently gotten back into wrenching on Subarus again. It has been a little bit since I have done any gasket work and I want to make sure I have good information before I start laying down hard earned money for parts. 1. I am looking to put together a frankenmotor with a 97 or 98 2.5...
  25. I have just recently gotten back into wrenching on Subarus again. It has been a little bit since I have done any gasket work and I want to make sure I have good information before I start laying down hard earned money for parts. 1. I am looking to put together a frankenmotor with a 97 or 98 2.5...
