Search the Community
Showing results for tags 'timing belt cover'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. Hi all, Recently had the timing belt on my DOHC skip some teeth. Was a brand new belt kit including tensioner. Was a Gates-brand. Well, I reset everything and about 500 miles later I believe it has skipped at least a single tooth, so I've parked it. I will purchase a brand new Subaru OEM belt and tensioner for it. My question centers around parts interchangeability. After perusing through opposed forces: http://opposedforces.com/parts/impreza/us_g11/type_28/engine/timing_belt_cover/ I've noticed that the '00-'07 WRX wagon has a 2.5L motor with timing covers that have timing belt guides for the cam sprockets as well as the crank. Any reason that these shouldn't work on the EJ25D? I'd like to add some additional security to the system. It seems to keep jumping off of the cams on the passenger side. Thoughts and advice will be appreciated. Greg
  2. Engine type EJ251AXBWL in a 2002 Outback, the AC belt jumped and was wound up behind the timing belt cover and the crank pulley. Part of the timing belt cover was melted by the crank pulley which was rubbing on the timing belt cover. I removed the crank pulley and the timing belt cover. The timing belt seems to be a good condition with only 40K miles since it was last replaced. The timing belt cover is slightly bubbled near where the crank pulley would be. The crank pulley itself has a couple places where there are tiny notches broken away. My first question is, has anyone seen this before? I am trying to figure out the cause of the AC belt failure. Looking at the Alternator Belt, this belt is well worn with cracking and a couple of missing pieces of splines. Now I am in the process of ordering replacement parts. Besides the Alternator and AC belts, and the timing belt cover, do you think I should replace the timing belt cover gaskets? I could take a file and smooth out the tiny notches in the crank pulley or should I replace it too? Thank you in advance for your comments!
