Search the Community
Showing results for tags 'trans temp light'.
I have an 03 Outback 2.5 A/T w appx. 184k miles. Trans has been replaced and the previous owner took good care of and maintained the vehicle well. The past several months I have had starting/idling/stalling issues. This general is worse when the vehicle is cold. It is hard to start without giving the accelerator a little help it most of the time will not start and keep running. It will stall if the idle is not kept up but when it does it runs fine. Sometimes it will idle and or start on its own without help, but that is generally only when it is warm, however can periodically do so on a cold start. When it stalls out, often the "AT Oil Temp" light flashes. The car is not throwing any codes. When these issues first started the symptoms where worse and the idle on a few occasions started to run high on its own, yes while driving which was quite dangerous! A few weeks back I ran some Seafoam into the intake into two different areas as per the bottles instructions to try to ensure that all cylinders where feed properly with the remains in the fuel tank. I also cleaned the throttle body out the best I could (air filter good, pcv valve iffy.) I did not get the standard heavy white smoke on start up that I normally do on other vehicles leading me to question whether the process took properly. I had a mechanic tell me to reset the computers values by disconnecting the negative lead & touching it to the positive side and leave set for 15 minutes or so. All of this seemed to do the trick. However, it started again and I brough it to my mechanic. The only thing they could find was a reported vacuum leak next to the intake. That certainly could do it and assumed that when I reassembled the air cleaner, I must have not made a proper connection and was gald that was the problem. It was not. THe car is still doing the same thing. I am going to try and replace the fuel filter and pcv valve next but if that doesn't do it, I am stuck! Suggestions!?! Btw: The TPS switch was tested and all that seems to be good. Please HELP!?!
- 14 replies
- throttle body
- tps
(and 5 more)
Tagged with:
