Search the Community
Showing results for tags 'transfer case'.
  • Search By Tags
    • transfer case ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 11 results
  1. Please see my video at this link: https://drive.google.com/file/d/11FP39hKrU2XqiSRT4n7GRie5ra_5cdiY/view?usp=sharing I was experiencing a vibration at speed. It felt like front wheels/bearings/balance... but I would slip it into neutral and it would roll just fine. I figured it was "drive-tr...
  2. I have a 88(I think) dual range transmission with a blown ring and pinion. Instead of buying a new ring and pinion from subaru for $500 I picked up a gently used 93 manual push button transmission($100) with the intention of taking the ring and pinion out of that. The transmission is perfectly fine...
  3. Hi folks, It's been a while since I posted here, 'cause the wagon has been running fine, but a BAD THING happened today. I was toodling home through my neighborhood when, upon starting up from a stop at an intersection, I heard a CLUNK and lost motive power. the engine was running and revving, a...
  4. This is my first Subaru, and I love it. It's a '98 Outback with 5-sp manual, about 165,000 miles. Last night I was up-shifting through a corner, driving normally, and suddenly the car just stopped moving. There was no noise or anything. Now I can shift through all the gears without using the clu...
  5. What type of fluid is used in subaru gl transfer case 4 wheel drive!
  6. Hello! My name is Corey and I live in Arvada Colorado and own a 94 Subaru Loyale Wagon and would like to beef it up. Get a lift on it maximize my engine power and upgrade the tranny/drive to allow for some off-roading and mudding. I invision a "mad max" style road warrior car and i wanna do i...
  7. So i have an 84 GL wagon, just finished the 5speed swap. The 4wd is stuck in 4hi. not with the shift linkage or with pry-bars am i able to move it to 4low or 2wd. I'm supposed to make a few hundred mile drive tonight and I don't suspect id be doing very well on the "new" 5speed stuck in 4wd. Any clu...
  8. Hey guys, I got a 1990 lego, manual 2.2 and i'm in my final stages of making it a vehicle that can survive where I live. Lifted, Locked, Updated breaks, quality rubber, etc. I would like to be able to gear it down with either a older model transfer case or just fully change the first gear ratios...
  9. Gloyale
    Trooparu
    Spent Halloween working on my own Frankenstein super lifted T-cased Subaru project. 86 Isuzu Trooper diesel Front frame. Cut just behind the torsion mounts. Keeping the Isuzu A-arms, knuckles, hubs, brakes. Hooking up to Subaru 4.11 Diff using hybrid Isuzu and EA81 Axles. EJ steering rack wi...
  10. Hey guys.... first post, here. My wife's 2004 Outback 2.5 4EAT was experiencing the infamous rear wheel Binding while slowly turning into a parking spot. I knew it would be a rear clutch pack and Duty C solenoid. I had the dealer do the work, since we needed it done in 3 days. We were movin...
  11. We own a 2007 Outback and had to replace the Head Gaskets 2 years ago with only 85,000 miles on the car for about $2200 (plus timing belt, etc. for a grand total of $3k). Now less than two years later, with 111k miles, we are being told that the transfer case may need to be replaced based on the ra...
