Search the Community
Showing results for tags 'transmission leak'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 3 results
  1. I have a 1991 loyale wagon 4wd ea82. I have been browsing this forum for a while and it has helped me troubleshoot and fix many issues on my wagon. Just when I think I have the ol girl in tip top shape this happens. After I use the push button 4wd and park/ get out of the car there is noticeable smoke coming out of the engine bay. It looks like there is some fluid dripping onto the exhaust. It does not smoke in fwd. why would it only smoke after 4wd? This is the first time I have not been able to find an answer in previous posts. Thank you in advance for your help.
  2. I have a 1991 loyale wagon 4wd ea82. I have been browsing this forum for a while and it has helped me troubleshoot and fix many issues on my wagon. Just when I think I have the ol girl in tip top shape this happens. After I use the push button 4wd and park/ get out of the car there is noticeable smoke coming out of the engine bay. It looks like there is some fluid dripping onto the exhaust. It does not smoke in fwd. why would it only smoke after 4wd? This is the first time I have not been able to find an answer in previous posts. Thank you in advance for your help.
  3. OK, here goes. Have a bad driver side front diff oil seal. Doing the CVs while I'm at it. Background- had a center diff bearing fail (shatter) 20K ago, split the tranny, found the bearing fragments and replaced no problem (also found some other old fragments of hardened metal from something else which failed and was repaired prior to my owning it). Kept the old seals and slid the halves back over the diff seals. Did not reset the backlash with the differential side retainers when it went back together (pops reassembled while I was at work, he couldn't help himself). Must I pull the trans to do this job like the manual calls out, or can I simply pull the side retainer, swap the seal & O-ring and reinstall the side retainer to the same exact point (indexing its original position/turns)? If I must pull the trans its all good, have all the necessary tools/equipment.
