Search the Community
Showing results for tags 'transmission oil change'.
I have a outback impreza with about 130K miles on it, and I would like some help with what brand or type of transmission fluid I should get? i have never done the transmission fluid change, so i decided to hop on this forum to find help from more knowledgeable people. Also I heard that if i am going to change the front that i should also change the fluid in the back differential, is that correct? My other problem I have noticing or hearing is screeching sounds from my belt(s). The first time i heard the screeching sound would be when i would turn on my ac in the car. Every time the ac is turned on, the screeching sound would be there for a few seconds and go away then some times it screeches as i would be driving. Any advice on either topic would be awesome! Thx!
Hi .... been a fan of subaru outback ever since drove a rental back in 08. have 2015 2.5 outback (not pzev) done close to 30k miles i have been going to the dealer for 6k oil change service till 18k miles and once after and napa auto as always felt the dealers fleece... need advice on getting his 30k health check... 1) Transmission oil change - what should it actually cost if done right (labor & oil costs) (couldnt locate any mention of oil grade for transmission) 2) is it worth getting an extended warranty that i got advertised by a mail from subaru usa (89 bucks per month for 10 months) hadnt thought much into getting one but awork mate mentioned his 41k mile forester had a busted bearing which cost him 1200 $ at the dealership 3) are there other items to be looked at during the 30k health check - other than engine oil change, oil filter change, cabin air filter change and ofcourse the ?
