hello all, I'm new to the forum...
I'm swapping a 96 ej25 motor and TZ102Z2ABA transmission into my 99 LGT (ej25 motor, TZ1A2ZJEAA transmission)
The research I've done shows the 4.444 ratio on both transmission to rear ends. (please correct me if you have differing info)
Everything lines up the same except the plugs from the car to the 102z2aba transmission are different.
The plugs have the same number of pins but are different in shape. The wiring from the old trans to the new are different colors.
I can't find a wiring diagram or info from someone that has done this swap before and am not sure where to go from here...
