Search the Community
Showing results for tags 'transmission problems'.
  • Search By Tags
    • transmission problems ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. I just had the shaft seal replaced due to leaking and had bushings replaced on 4wd shifter. Drives and shifts good, but will no stay in 4wd, shifter will pop back up on hard surface, so tried going off road and when on hard dirt the same thing unless I am in soft soil after which when it hits hard g...
  2. I have a automatic that pops in and out of gear in forward or reverse with a sharp jerk. Is there a solenoid or something that controls this?
