Search the Community
Showing results for tags 'transmission swap'.
My transmission is TY752VACAA the donor trans is TY752VA5AA. Both have exactly the same gear ratios ,except for 5th. Mine is .780 the donor is .825. what if any issues might I have, without swapping the rear diff or driveshaft. The Impreza that Im getting the trans from was originally an automatic. Someone had done a manual swap on it, I checked the vin decoder. The donor has a 1.8l ej18 engine in it now. I have a 2.2l ej22. I’m unsure of the rear diff on that (donor vehicle )if it was swapped when the manual was put in. But with all the gearing the same other than 5th, should I be good with just swapping the transmission?
- 1 reply
- transmission swap
- 5mt
(and 5 more)
Tagged with:
So i currently own a 2000 legacy wagon, and am concidering buying a standard impreza for use of parts, i want it's manual transmission, sway bars if possible, drive shafts, and I know I will need it's rear differential. I was wondering if anyone has any idea how compatible these two vehicles are?? A response would be greatly appreciated.
- 4 replies
- transmission swap
- 1997 impreza
(and 3 more)
Tagged with:
Hey guys, New to the forum world! I've decided that I have too big of plans for my legacy than i really am capable of.. Though, with as much time as i need, I plan to have this thing running in better condition than when it was originally produced! Though, I may need the knowledge and advice of many other drivers... my first issue I would like to deal with is my broken front sway bar. Any ideas of how I could find such a part without ordering online and costing myself an arm and a leg?? Thanks in advance for any help!
- 3 replies
- Help
- transmission swap
(and 3 more)
Tagged with:
I have a 99 OBS and I love it except that it's not a manual. it has 270,000 miles but I just replaced a lot of parts and the only thing wrong is a slight exhaust leak and play in the rack and pinion. My friend is selling a 98 legacy outback with 210,000 miles and who knows what maintenance history but it is a manual. I'm tempted to buy his and sell mine (yes a manual means that much to me) but I'd rather swap my finicky AT for a 5 speed. Is this even a viable choice, or a ridiculous undertaking that cost a lot of money? Any advice or links would be greatly appreciated as I really don't know what would be a smarter choice.
- 8 replies
- transmission swap
- manual transmission
(and 4 more)
Tagged with:
Just bought a 2nd Generation 1988 Subaru GL 3 door hatchback 4 speed manual transmission with dual range (4 hi, 4 lo) with an EA81 engine. I've been searching this forum, but haven't found alot of info regarding the benefits of swapping my 4 speed manual for a 5 speed? There are alot of posts about swapping an automatic for a 5 speed, but that doesn't help me. The main reason I'm interested in doing this is I do alot of freeway driving, and I go about 65-70, which puts my rpms in the 3000-3200 range. I know that's not great for the engine, and I want this engine to last. I read on one post where a person said by swapping to a 5 speed, it lowered the rpms by 500 while highway driving. Is that true? I wanted more confirmation than 1 person before considering this. Are the gear ratios the same, or will I be able to be at a lower rpm going 65-70 if I swap to a 5 speed? What does a swap involve if I'm going from the 4 to 5 speed? I read that they made them in 5 speed with the EA 81 engine those same years, mine just happened to have a 4 speed manual. Can anyone confirm it that's true, Wikipedia isn't always correct. I would think it would be easier to find a 5 speed transmission from an EA 81 than EA 82 if that's the case..... Thanks for your help and replies!
