Search the Community
Showing results for tags 'turbo heads'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. Ok, need some help here, hoping someone can help out (@GeneralDisorder?) First GT forester series 2 (2002) head is off. Piston is noticeably different - GT on the left, EJ20G/whatever it is on the right. This EJ20G/x piston is what came with the heads I’ll be running with. I’m now worried the valves might hit the pistons. I’m hoping I can put one head on (not fully torqued down and thinking without the gasket too), refit the timing gear and rotate the engine to find out if the valves will kiss the piston. Also to note, the GT had thin MLS head gaskets, the HG units I got ages ago in prep for this build are thicker composite gaskets (OEM). I really don’t want to swap pistons on this thing! Here’s hoping! Some background info on the build: this will be going into my Gen1 RS turbo. The heads match the intake bolt pattern and the intake equipment matches the engine management system, hence the head swap onto a known good block. And no, I don’t want to run later model management or run aftermarket management, please leave comments like that to yourself thanks! Cheers Bennie
  2. I'm getting a couple ea81 turbos soon, - one with a bad bottom end, the other is assumed running condition - and I'm considering using the good ea81t in a ea82 wagon with SPFI. I don't have the ecu's or the MPFI wiring. Here's what I'm thinking: -EA81T block w stock turbo cam -EA82T Heads shaved .025", maybe not( I'm aware of the change in valve geometry) -EA82 Pistons(compression bump) -EA82 SPFI (Already in the car) Ok so I've dropped ea81's into ea82 cars before with spfi, but I have no experience with the turbo ea81s. I'm not gonna use the MPFI injectors, but they'll stay to plug the injector holes. Once I get the compression up, my big question is the EA81 cam...will it be worthwhile? Gutless(more gutless than a stock ea81 under ea82 spfi)? I'm not interested in building an ea81 turbo, but I have these parts and I wouldn't mind a running engine. I couldn't find any info in going from ea81 turbo-->ea81 non-turbo w/ spfi or weber, any input is appreciated! TIA Josh
