Search the Community
Showing results for tags 'used motor'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hoping someone can help with this. Just did a like for like engine swap. 2008 Impreza, 2.5i SOHC, Manual transmission. I have verified that the injectors are clean, cam and crank sensors are working perfectly, checked injectors with a noid light and they are getting pulse signals just like they should, all timing components have been replaced including water pump and I have made sure the timing is set correctly. I have also seen that I'm getting an rpm signal on a live data scanner. When I crank the motor, it gets up to about 130 rpm but won't fire on it's own. The spark plugs are all gapped correctly and are getting spark, although its a yellow color less than a blue. No matter what I do, the engine will not start on it's own. I've tried both styles of crank and cam gears and have the same result from both. Someone please help me with this, I need this car to run. Thanks in advance.
