Search the Community
Showing results for tags 'vacuum advance'.
Help request: I'm trying to keep my one and only car, 1984 Subaru GL wagon (manual, dual 4wd, 1.8L) going. Disclaimer: I am not a mechanic, albeit reasonably handy with mechanical things. It has problems going uphill, sometimes even in 1st gear, especially when it's cold and snowy. I suspected the vacuum advance. Took it to local repair place to have vacuum advance checked and replaced if needed. They charged me lots of money, replaced spark plugs and wires, and did nothing about vacuum advance. Upon requesting info about why they had not done the requested repair, I was told that the vacuum advance was bad. They could not find a replacement. My query: Where can I find a replacement, what vacuum advances are compatible with this machine, and is this likely to fix its traumatic uphill behavior? Can I do this, or do I need auto mechanic help? Also: oil pump is leaking significant amounts of oil (a quart every few weeks). Is it repairable? Do replacement units exist? Is this something I can do myself? Many thanks!
I have an ea81 I know for a fact the vacuum advance on my distributor is bad. The problem is I cannot find a suitable vacuum advance to replace my current one while i send it out for rebuild(have to get to work) So whats the DIFFERENCE BETWEEN ADVANCES FOR MANUAL AND AUTOMATIC? also is there a difference between advances with california emissions and without? They're no advances available for my 83 GL brat but I believe a 83 accord will work but the only one i can find is for an auto trans and the brat is 4 speedmanual and also my daily driver til my machinist finishes retrofitting my other subarus control arms
- 5 replies
- distributor
- vacuum
(and 3 more)
Tagged with:
