Search the Community
Showing results for tags 'vacuum lines'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 6 results
  1. I am in the middle of a carb swap from a carter-weber to a hitachi and I just got the new intake in but the vacuum line cp (hard vacuum lines under intake) are different. not sure what to connect to what. curious if anyone has a diagram or information. thanks
  2. Hi Hoping for some help from knowledgable eyes. I have a Subaru GL 87 1.8 Carb. **I recently replaced the overcharging alternator (bad regulator). After timing belt procedure it decided to quit. Overview of this engine- 1. Here is the biggest problem, rear of motor and of alternator area: This hose (below) is broken the engine shakes a little more after, and when i cover the hole it calms down. I found the possible piece ( top) Not sure where else it was connected to? 2. I also found this guy hanging around, looks like it should be bolted down, but what is this? 3. Plugs behind Alternator not connected, what are they for? 4. disconnected plug Under Hood Driver Side Top, Where does it plug? what is it? the black broken tube (arrow) a problem? 5. On Passender Side Top disconnected and unknown plugs, what are these? Thanks for any help
  3. Does anyone know what the ECS light is on the dash? I recently did a weber swap on my 1984 Subaru DL. Var runs better and stringer than ever. My only concern is that afther a while of running it (15 minues or so) a ECS light comes on. Is this anything serious what could it be and how do i get rid of it. I never had any lights come on before the swap. Thanks
  4. I have an 81 gl an I rebuild the card but cant remember were most of the vacuum lines for it go.
  5. Hi all, I've been searching this morning on information regarding the charcoal canister. Anything that I've come across dealing with this, only pertains to 2.2-2.5 swaps.. The Legacy donor vehicle had hit a deer, so the passenger fender/radiator/light/charcoal canister were destroyed. I have the EJ in the Loyale now, and I'm wondering how to correctly hook up the Loyale's canister to the EJ motor. Is this possible? I believe I connected the two (available) EJ lines correctly. But there is the third line off of the cannister that I'm not sure where to hook up. It says VC I believe. My next question is about hooking up an EA temp sender unit, and a fan relay together... I will be hooking up two 10" fans to my brand new EA82 single row radiator. It is identical to the old one that I pulled out. There is a port on the side, that I believe I can put in some type of temperature sensor in... On to the subject... I will be using the EA temp sender so that I can keep the gauge working. I also will be using a 30amp relay/circuit/switch system to operate my fans. I do not want to make a sleeve for the sender, then to put it in-line with the upper radiator hose. My idea is to make a T-adapter that can be used in that radiator port. Any reservations? I was thinking of getting a small length (maybe 1/2" long) of threaded pipe (to the size of the hole..) then attaching that to a T of some sort that I can put in the temp sender for the gauge, and one for the fan sensor... That might not make any sense, my brain is firing sparatically from all the coffee... This is similar to what I'll be using for the fan relay... Any thoughts would be great! Thanks, Greg
