Search the Community
Showing results for tags 'valve bend'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. So there has been alot of questions about bent valves from timing belt failures. It's been my experience that if the belt breaks, it surely bent valves. But sometimes, if the belt just skips a few teeth, things are okay. Example : this '06 forester started running incredibly rough about 10k miles after the owner did his own timing belt replacement. Pulled the covers, and found this IMG_2926 by Dans Subaru, on Flickr IMG_2925 by Dans Subaru, on Flickr He had striped out the lower idler hole, and it had walked funky out of the hole and forced the belt against the inside of the cover until it shredded and it had skipped 2 teeth on the passenger and 4 teeth on the drivers side. After tapping the lower hole deeper, and installing a longer bolt to hold the idler, I installed a new belt and did a compression test. 165+ in all cyls. Lucky SOB So if yer belt has skipped, don't go immediately tear the engine down. Worth a compression test first.
