So I just put a new timing set on my 86 GL-10 4WD Wagon and it won't start. I'm 95% sure the timing belts are on right. The car has fuel, spark, equal compression in all four cylinders, and the ignition timing is spot on. I pulled the intake off and cranked it over and there was air coming out of the intake on the compression stroke. Does anyone know if this is just a valve timing issue or something else?
