Search the Community
Showing results for tags 'variable valve timing'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Need some help after our actions did not fix the problem: Outback got an oil change and check before a trip in September, at 135K miles. For the first time I experienced the car not shifting into lower gear when accelerating up a hill on the highway. The RPMs went up, but no downshift. I slowed down and the problem did not return. Two weeks later the car died at idle in drive on an incline and threw code p0028. Car started idling rough at a stop or when in reverse at very low speed. Sometimes it died but restarted fine. We found some moisture in the spark plugs and tried removing. Ended up breaking a wire so we took it to our trusted mechanic for new plugs and wires. After that the car performed well for two weeks until last week on a trip in the foothills. Threw the p0028 code while on a straightaway, but the idle problem did not return like before. We cleared the code and chose to install a new variable valve timing control solenoid. We also cleaned the switch. The code is gone but the car is again idling rough and sometimes dying at idle in drive or reverse. Today we put in a new switch. Husband confirmed switch and solenoid are opening properly. But no change to our rough idle. We drove it around the block, it did not throw a code. What is our next best option?
