I'm having a problem with the choke on my weber, can't seem to sort it -it won't catch and hold, and the way the linkage is behind the housing, I can't see what is going wrong. If I pull off the air filter top I can hold it and make it catch and stay, but it won't 'hook up' by pressing the pedal. I've tweaked the screw this way and that, and made adjustments to the spring, but nothing is working. Done the setup as described by redline guide but it is a vague description, doesn't really detail what is supposed to be happening mechanically.
It's a 32/36 electric choke. Don't really want to convert it to manual choke -it's new and it should work as designed. Never had issues with my old weber on the last car, and I consider myself pretty good with carbs generally, have lined out many different kinds.
Anyone help me out here before it gets cold and I need it?
