Search the Community
Showing results for tags 'wiring harness'.
Any help on finding a 1993 Subaru Legacy sport ecu to engine wiring harness? MT/turbo. I’ve looked all over the place to find one but no luck.
- 12 replies
- ecu
- wiring harness
(and 1 more)
Tagged with:
hey all, I recently acquired a 1990 legacy. Drove it for a couple days, then all of a sudden I'm driving along and all of a sudden the car dies instantly with all electrical gone. Checked the battery and alternator and both are good. Tracked it down to the fusible link in the underhood fuse box...
- 11 replies
- 1990legacy
- fusible link
(and 5 more)
Tagged with:
I am in desperate need of a 1994 Subaru Legacy EJ22 Wiring Harness and ECU in order to do a Volkswagen Vanagon Engine Swap. I have a custom made conversion kit through Kennedy Automotive out of Palmdale California that is made specifically for a 1985 Automatic Volkswagen Vanagon and a 1994 Subaru Le...
- 9 replies
- vanagon subaru swap
- vanagon
- (and 10 more)
Hey Im new to this forum and a bit new still to subies but i have this 1982 BRAT and i just picked up a almost complete EA82T to swap into it minus the wiring harness and ecu so i am in need of one does anyone have one that they would sell for cheap?-- i need every single wire and the ecu and also t...
- 1982 BRAT
- Wiring harness
(and 2 more)
Tagged with:
hello all, I'm new to the forum... I'm swapping a 96 ej25 motor and TZ102Z2ABA transmission into my 99 LGT (ej25 motor, TZ1A2ZJEAA transmission) The research I've done shows the 4.444 ratio on both transmission to rear ends. (please correct me if you have differing info) Everything line...
- 5 replies
- transmission
- wiring diagram
(and 2 more)
Tagged with:
Just picked up a 1990 legazy auto for cheap. only got it cheap because a pack rat ate the engine harness up. so i got a new harness from a junk yard. replaced it and turns out it has been parked the past 4 years was im pretty sure the ignition control module went out. only cylinders 1 and 2 firing....
- 13 replies
Can somebody please confirm/comment on (e.g., re-fine) my understanding of how the Subaru A/C compressor and ECU work. As a background, I'm in the middle of re-wiring a Subaru harness to work with a VW vanagon, so I'm trying to figure out exactly how the Subaru wires and Subaru components will inte...
I have a '78 GF that I'm currently in the process of restoring from having an engine fire, and the wiring harness was so far gone I didn't think it was worth saving. Long story short, it's got a new wiring harness from a 1978 BRAT, and there are a couple of plugs that don't line up. There's one that...
Hey guys! My buddy has agreed to help me do a wiring harness with my 78 BRAT. He said if I get a kit he can help me build it, but he needs to know the specs I need. Anyone know of what the most reliable kit I could get to work for this? I also plan on doing the ea81 alt/disty swap when I inst...
