Search the Community
Showing results for tags 'xt-6'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hi there... I have a black 1988 XT-6 with auto trans and AWD that has been sitting UNTOUCHED in a garage (except for the piles of stuff that have accumulated on top of it) for the last 18 years. It was the SECOND car I ever owned, and I still remember thinking "Oh hell yea!" when I floored it out of the dealer's lot on a test drive. I think it had 80k miles on it back then, and 140k now. I've been thinking for awhile now about if it would be possible within reason to get it back on the road, and before I do anything I thought it prudent to seek advice on what's possible, and what needs to be done in what order (to avoid making things worse), from those whom have been there before I. So, I would appreciate anything anyone has to say about the topic, and thank you in advance. Here's some info I remember from before I stopped driving it...18 YEARS AGO. (And, yes, I remember dreaming, as apparently others have, about turbos, and apparently there was one in Japan only? I'd be happy with it moving under it's own power now. * 140,000 miles or so as it sits. It drove fine then but hasn't been started since. * Unfortunately, I cannot find any of the keys to the vehicle. (see my first post in the relevant thread, please) * At the time, I was replacing one of the front half-shafts. I think the core is still in the trunk. * The air shock system is in the attic and replaced with used coilovers I found from a FWD XT6 in a junkyard. Air ride was much smoother, but I didn't have an extra $1200 burning a hole in my pocket. (Any hints on shock replacements that will fit?) * In the past, I've replaced both valve cover gaskets, oil pan and trans cover gaskets, exhaust, diff. fluid, front half-shafts, CV boots, both timing belts, water pump, and probably oil pump? Obviously incidentals like brakes, plugs, wires, and distributor parts. Accel supercoil. Most of the work I did myself. I kept mileage/maintenance records but I have no idea where they are now. If I remember correctly, I used to average around 17mpg. * The ONE TIME I let my (ex) GF drive it, she mangled the front fender but there is a replacement in the attic, along with a replacement headliner if it's still ok. * I don't think the headlight washers ever worked. It made a noise like the pump worked in the passenger rear quadrant, but nothing came out; maybe clogged or I never found a separate resevoir, if there is one. * Power had stopped reaching the rear wheels. It drove fine otherwise, but before I was never able to spin the wheels on takeoff. I think I read somewhere there's a fuse or fusible link that activates some kind of separation mechanism or clutch, maybe it got stuck in the open position? Anyone know this problem? I never got further troubleshooting it beyond some wheel turning tests with the back end jacked up. I think that wound up being "normal"? Don't remember. * If you think that one's out there...my FIRST car was a 1978 rabbit that I traded a week's work for to my first employer because I needed to get to work and it was sitting in his back yard. It had a white body with black dash and blue seats, grey hatch, mahogany door panels, and a blue hood with a Mack bulldog bolted to it. GAS engine (with MPFI in '78!) but DIESEL 4 speed trans...it would only break 90 going downhill, but I towed all kinds of cars out of the snow in that thing...someone's jigsaw puzzle. Gotta have a laugh once in awhile. Thanks to all very much. Take care and be safe.
